todd foster
- Joined
- Apr 18, 2006
- 32
1999 johnson venom 200 j200stlec.Fresh rebuild on carbs,new fuel filter,idle screws 6 turns out.The lower left carb when looking at motor from the front is leaking fuel from a small brass tube just below the opening of the venturi.It runs out when engine is running and when not running priming bulb it squirts out.I thought the needle might not be seating properly so i broke bowl down and filled bowl with gas and when float goes up no fuel runs out of the fuel inlet.Not sure if this is the way to test float and needle setting but seems like when carb is on engine that the needle is not stoping the flow of fuel when bowl gets fuel and overflow is pouring out of this tube?Has not been doing this since rebuilds just recently.
