Gas smelling bilge
michaelsen
I just figured out why I havent catched anything lately. I had my rods and all the other fishing stuff stored in my bowrider underneath the floor in the ski/wakeboard department (not sure what it is called). Anyway, everything was smelling of gas. The storage room is right in front of the inboard motor with a hole between so the water can drain.<br />The boat is less than one year old and I know that it wont take much gass for it to stink all over. Is this normal or should I worry about a leak?<br /><br />Regards<br />Mike
Jack Shellac
Re: Gas smelling bilge
If you have a tank under the deck, definitely check it out thoroughly.
magster65
Definately look for a leak! And err on the side of safety, fumes are much more dangerous than liquid. You probably knew that... just trying to help.<br />Maybe you can ventilate the compartment a bit better?
