Gas tank...evinrude
thegun1942
Hi everybody....Can you tell me whether my 1972 lightwin 4 hp evinrude uses a 2 line gas tank or a single line one? The fuel pump appears to have only one inlet line, but I don't want to guess! Thanks,
Ken
jeff_smith_0423
Re: Gas tank...evinrude
Single line tank, standard OMC connectors. You can get a six gallon tank, two connectors, and a pre-fab fuel line at walmart for around $40 total. OMC abandoned the pressure tank concept somwhere around 1960. My '61 5.5 horse used a standard tank.
thegun1942
Thanks for the great info Jeff..I saw the parts you mentioned @ wallyworld last week, but I dinna want to buy them 'till I was sure. Thanks again,
Ken:)
jeff_smith_0423
FYI - now that i think about it, the WW tank may not be the 100% best recommendation. I've used them in the past and they're fair tanks, but they're prone to bloat if you forget to open the vent in storage.
Check out the Moeller "Topsider" tanks here on iboats -a much thicker grade of plastic. They also have a 3 gallon size which is probably more suited to your engine.
