Re: Gas Tank size '84 278 XLC Chaparal
So Little,<br /><br />Thanks for the info I'll look for a plate.<br /><br />We've swapped notes on our beloved Sea Drives on a few other posts in the outboard section. Are you still running good this year? <br /><br />I'll be breaking in a reman'd powerhead soon and need the tank mix @ 50:1, in combo with the VRO, to get the 25:1 for the break in. Foolish or not I plan to rely on VRO after break in!?<br /><br />My tanks is already full, but wasn't sure of tank size to calculate oil needed.<br /><br />As it turns out I found a listing for a 278 XLC Chaparral in the iboats classifieds, which indicated fuel capacity @ 120 gallons. Good thing, because previous owner told us it was 100 gallons. I knew it was more because we've put over 100 gallons in!<br /><br />Coincidence or not, about the same size as your Wellcraft, is this a typical size for an inboard tank on that size boat? My Chap is 26'6 with approx an 8' beam.<br /><br />I plan to now dump in 2.2 gallons of oil.<br /><br />R. Wood
