marksa1458
- Joined
- Apr 6, 2009
- 93
Looking for help on the general process of replacing gaskets - Do they typically go on dry or do you use some sort of goop? If you use a goop any recommendations on the type to use?
Right now changing out the gaskets in the fuel pump on a 1968 Mercury 500 2479530. I also need to change the powerhead to mid section gaskets, replace the water jacket gasket and want to rebuild the carbs...
Also, for those gaskets that are paticuraly challenging to remove, what is the tool of choice? Do you scrape off with a razor blade? How clean do you have to get the surfaces?
Appreciate any guidance - many thanks.
