Gasket Material?
SeaVue
Hello everyone.
I?m working on a Mercruiser 888 (Ford 302) and I need a lot of gaskets. I was wondering if there is anything that you can buy to cut out your own gaskets. :confused: Its going to be expensive replacing all of these and on top of that i need to wait a long time for them to ship if i order them online.
Bard1
Re: Gasket Material?
I've used cork and R.T.V
_chris_
Autozone carries 3 different types of gasket material in rolls, I have used alot of the stuff and it is very inexpensive.
SeaVue
Thank you.
Does it work good and is it hard to get a good cut?
lowkee
Cork rolls are cheap and easy to cut. The carb and water pump gasket on my boat are made from it. You have to match materials, though, as the metallic gaskets cannot be swapped with cork. Paper gaskets, however, can be.
SeaVue
Ill go check it out today. Thanks everyone.
indy440
you cant get an aftermarket 302 complete engine kit from somewhere cheap? Seems like they would be all over the place...
_chris_
It's easy to cut and for the small bolt holes I use a hole punch for paper and it works great.
OMCboater
I stopped using gaskets (other than certain critical ones, like head gaskets) a couple of years ago when i discovered Permatex Right Stuff gasket maker
http://www.permatex.com/products/Au...uto_Permatex_the_Right_Stuff_Gasket_Maker.htm
I know this sounds like a commercial, but honestly, I have no affiliation other than being a satisfied customer. I generally drive older vehicles that I maintain and repair myself and I have never had a single leak where I used this stuff. On the downside, if you have to disassemble where it was used......it is a bit of a chore because it works so well. Small price to pay for leak free seals, IMHO.
LongLine
McMaster-Carr sells all kinds of gasket materials. Big on-line supply house.
Tom B.
(LongLine)
SeaVue
Thanks for all the reviews. It was storming like crazy here yesterday and I didn?t get a chance to get anything done. I will check out a few of these things. They sell Permatex Right Stuff gasket maker in Advance Auto parts. Ill go check it out today. I think I might get that if it seems good. I don?t feel like cutting some of these gaskets since they have a weird shape. Ill let you guys know what I got and how it worked
