Gasket?Seal ..learn as I go
paintking46
From looking at some parts on this site the leak I found.. more like a good steam would be from the thermostat housing I think.. Another leak I found was the gasket/seal the section above the lower end the top was leaking. Just looking at im guessing starting at the lower end to get it apart..In the one pic the water is spraying from the bottom on the housing that the fuse hook up is bolted to.
