Gasket Sealant and Loc-tite
78 MarkTwain
I am in the process of installing new head gaskets and head cover gaskets in my 1989 115 Yamaha. Looking at the manual it says to use Loc-Tite on the head cover s. What strength should be used? Also, is any gasket sealant supposed to be used with either the head gaskets or the head cover gaskets?
99yam40
I would think the service manual should give you what kind to use
78 MarkTwain
No Title
I would think that too, but I have read through this manual three times and this is all I can find about Loc-tite. In the powerhead section it doesn't mention anything about applying loc-tite when installing the thermostat or the exhaust cover. Unless I am missing something it does not specify what type of loc-tite to use. I would assume a high heat medium strength would be adequate, but that's why I am asking the question.
99yam40
In the manual for my C40 it shows a picture or a tube with LT written on it with the number 572 right below it on the parts breakdown of heads, head cover, and exhaust cover bolts .
My guess you are talking about the bolts and not the covers themselves.
I ended up using a Permatex high temperature thread sealant with Teflon, Part #59235 I picked up at the local auto parts store.
I could not find the LT 572
I think it was recommend by a Yamaha Master tech if my memory is working
