gasket sealant?
relics hunter
What sealant should be used on the exhaust cover gaskets? I currently have some aviation form a gasket but not sure if this will work. any thought's are appreciated.
HighTrim
I personally like the OMC Gasket Sealing Compound with the built in brush.
F_R
Your aviation stuff will work (assuming it's the grade with a brush in the can). OMC Gasket sealing compound is sure a lot more pleasant to use though.
