Joshua Nichols
- Joined
- Jun 29, 2009
- 1,431
So last summer I did some maintenance.. Bellows and such.. Anyhow when replacing the OEM gasket I noticed that the Aftermarket gasket was different... It wasn't cut out for the little inlet seal.. I went ahead and replaced it with the aftermarket Serria one..
Well now I gotta remove the outdrive to make some checks and now I am thinking I will Pick up a couple of those OEM gaskets and seals to keep on hand cause there isn't much of a price difference...
I was wondering how come the aftermarket is different.. Does the aftermarket seal off better or something? Seemed kinda weird to install the inlet seal on the backside of a gasket, but that how I did it
I guess I will know how it all turned out after I drag it off.. Seemed to work fine lastime I was out.. Picked up water no problem and didn't overheat...
Here is some pictures
