1974 chrysler 75hp --757HA<br />I am replacing my impeller and my powerhead (costly mistake
) and have some questions on gaskets needed. First of all when I replace my impeller, do I need to replace the driveshaft seal that sits in the top of the water pump housing? Second do I need to replace the water line tube seal that is on the top of the water pump housing? Also do I need to pull up the plate underneath the impeller for any reason and replace that gasket? Also when replacing the powerhead it appears that I need possibly the upper and lower kingpin gasket. (thanks eurolarva) I have been having a hard time finding these gaskets, can I use some type of gasket maker in place of these or does anyone know where I can find these? <br />Thanks
