texasvet54
- Joined
- Nov 5, 2010
- 267
Hello All,
I found a message on iboats saying to do a search for "making oil" and I now have a pretty good handle on what has happened to my mercruiser.
Basically, I needed a new carburetor back in November for my 1998 Mercruiser 350cid. So, a local shop ordered and installed a remanufactured one for me to the tune of almost $800 installed. The stalling when putting into gear problem was solved and I thought that all was right with the world. A few weeks later I noticed that my oil looked a little thin so I put new oil in but I left out one quart to see if the level was going to rise. Well, after running the engine through the winter every so often for a total of three hours, my oil is again thin and it is above the full mark on the dipstick. I pumped about a quart out and put it in a clear plastic jar and headed over to the marine shop. They instantly told me that the oil smelled like gas, something that I had suspected, but they were at a loss as to how it could get there. I should add here that both of the guys were young and said that they only worked on outboard and that the owner would be in Monday to take a look at it.
Well, after reading all of the posts about gas in one's oil and looking at the timeline for when my problem started, it looks to me like I got a bum carb. It's either that or the fuel pump, but I'm not looking in that direction yet because the problem started after a new carb was put on. So, I'll be talking to the owner on Monday about getting me a new carb.
My questions to those more experienced in this area than me are, is there any chance that I've damaged any seals or bearings in the engine by running it for a few hours with gas in the oil? The engine never got hot and the oil pressure was always over 30. Also, when I get a new carb on, should I change the oil and run it for maybe half an hour or so and then change the oil again in an effort to wash out any gas?
Any other recommendations would be appreciated.
Thanks,
TexasVet
Thanks,
TexasVet
