Gauges I might need
redlinj
I have recently repowered my 1988 21’ Sylvan from a 1982 evinrude 150 to a 2020 Yamaha F115! I will need a new tach for sure! What about other gauges? The controller that came with the motor is an aftermarket 703 with a 10 pin plug and another shorter harness which I’m thinking would go to gauges. Hate to say it but I’m a bit confused with this newer technology! Any guidance on gauges etc. would be much appreciated! Thanks!
dingbat
Digital motor…would need a A/D convertor to support existing analog gauges. Depending on your budget, could replace everything it’s a Yammi digital “information station” display
Could use a standard yammi “command link”if you don’t mind scrolling thru menus to see everything
boscoe99
A 2020 Yamaha F115 will support either analog instruments or digital instruments.
Yamaha offers needle and dial analog instruments, analog instruments with digital displays and digital instruments with digital displays. And the motor can be connected to an NMEA 2000 MFD if you want to see engine and fuel data on it.
