I have just bought a boat with a 1986 Johnson 60 on it (AJ60TLCDS ser.A0614076) and the tacho and trim gauge don't work. I cleaned up all the connections on the trim gauge, and as soon as the ignition is turned on the needle drops off the bottom of the scale and stays there. I presume this means the sensor is open or short curcuit and the needle is jumping to one end. Where is the sensor and is there any common problem to be looking for. The tacho doesn't even glitch when power comes on (which is a bad sign). The needle just sits at about 5500 rpm permanently. Again, any common problems to look for?
I know it's not the end of the world if these don't work, but I'd like to fix them if I could.
