Gear case level and drain screws
Vic.S
Sometimes one sees socket head ( Allen type) drain/ level screws in the parts lists but most seem to have slotted heads
Anyone any idea why socket headed screws are not universally used.
This is just new ideas.-----The screw slot ones require that the screw driver is properly lined up and pushed into the slot.------Not so with the allen key ones.-----If the allen socket / wrench is in the hole it is " self aligned " and holding.----Just turn it.
Vic.S
Yes I know the difference .
On the face of it the Allen key ones would be better, by not relying on a screwdriver .in a slot
I wondered, therefore, why socket headed screws were not used in preference to slotted ones.
Is there some snag with socket headed screws that I am not aware of?
Maybe it costs 3 cents more to produce each one.----Maybe no manufacturer offered them.-----Maybe the hex head is the preffered type for robotic assembly that is used today.----ETC , ETC .
hardwater fisherman
According to another parts site BRP is no longer making/using the slotted fill and drain screws...And have replaced them with the allen socket head..
Crosbyman
I stripped a couple of allen heads …..but apparently one does not have to torque them excessively to stay in place
but I never had issues with slotted ones and a good screwdriver to match it
your call....
jimmbo
The issue with the slotted screws, was too many Brainiacs would insist on using a Too Small of Blade resulting in a Damaged Slot
Found one with allen head stripped too.-----Stainless is often quite soft.----Had to use the hammer & chisel method to get it out.
Crosbyman
imho 5/32 Allen is to small and they probably introduced a bigger problem with people torquing them to much into mush ...
7/32 or 1/4 would have provided more surface area :frusty:
On outboards it does not matter what you do.-----Somebody will figger out a way to damage it.-----Folks invent ways to destroy motors almost every day.
jimmbo
First Slot, currently Hex. Coming soon, Torx. A full circle, as some Mental Midget will return to a Blade driver on it
