Gear Housing Section to fix
Horse4190
I am trying to fix my Gear Housing section from a 1989 Force Outboard 85HP motor. During oil change, I removed the gear shift arm by mistake and causing a lot of trouble - no reverse/no neutral. From the attached sketch, can you please help if part #45 to be connected to part #27 or to any other parts?? Thanks
  • GEAR HOUSING - 1989 Force Outboard 85 856X9C [Force] _ Crowley Marine.pdf
gm280
Looks like it to me. That is your shifter rod and the clutch dog. Sounds like you have removed the pivot screw and didn't get it back into place correctly. Therefore you are stuck in forward forever. You have to realign the pivot again and install the pivot screw for it to function correctly again. With out being there to verify, that is my guess!
jerryjerry05
No, the 45 and 73 fit together down inside at the bottom after 45 and 46 get hooked up.
25 has a groove on one end and 73 fits in it.
The pivot screw(you removed) fits into 45 the cover needs to be removed to make the job easier.
25/26/27 fit together first.
Not that hard a job.
Horse4190
Thank you Jerry the expert. This one is more clearer. I will try to work on this tomorrow.
Horse4190
Hi Jerry. I did the work and opened the cover. I got 45 and 46 hooked up and inserted the pivot screw (32) to 45. I can only see 25 and unable to see 73. Is that I have to shake or toose up and down the whole gear housing section to find/see 73?. Thanks
jerryjerry05
25/26/27 go together, then 73 gets installed on the end of 25 with bearing assembly grease (see note below).
45/46 is installed with the pivot pin 32
Then the drive shaft assy. gets inserted into the drive.
As it get close to the coupler you lift the shift rod and try to engage the 45 and 73 together.
The half moon shaped carrier locks= make sure the grooves are clean.
They can be installed with the same grease to keep them in place.
Bearing assembly grease= easily dissolvable grease, once the parts work and move the grease dissolves and
the parts move easily. regular grease is too thick and won't dissolve as easy.
Horse4190
Thanks Jerry on this. I tried to work on this last night and afraid as I thought the 73 (Yoke) was missing. After shaking the whole LU and tossing up and down, the Yoke came out (very small). Pin Gear Shift (25) is still attached to 24. To attach this Yoke 73 to 25 and 45 is quite challenging, but I will try to use a thread or a nylon rope/wire and will see what happens.
jerryjerry05
If the shift shaft cover's been removed, it makes it easier.
Remember the assembly grease is needed.
Other types won't dissolve when used.
Horse4190
Jerry, which one is the shift shaft cover - is it the Gear Housing Cover (53)? I have that removed already.
Horse4190
I have succesfully connected them all without using assembly grease. I used just the thread and a metal stick. many thanks for your help Jerry.
