pete44
- Joined
- May 7, 2005
- 189
Hello. Cannot get my lower unit (gear housing) of outdrive to mate back with upper unit of stern drive..I followed procedure as described on this site : www.mercstuff.com/water_pump_inst.htm ....I made sure boat is in forward gear(upper shift shaft straight ahead-facing stern).. (and that shift shaft was clockwise and placed slight pressure on propeller shaft in counterclockwise position to lock lower unit in forward gear..it "tries" to go but has about a 3/4" gap all around....meaning to me that splines are not lining up...After I installed water pump I made sure I could turn shaft on lower unit...(with both hands and some force) to check impeller..it had a good deal of resistance...maybe I did something wrong putting pump back together.....Thanks,Pete
