Gear lube slowly dripping from pitot intake on Bravo One outdrive
Philster
Title says it all.
Definitely a very slow drip from the pitot-speedo (tiny) hole on front of outdrive.
Don't know how worried I am supposed to be.
Don S
Re: Gear lube slowly dripping from pitot intake on Bravo One outdrive
Pull the drive, drain the gear lube, and do a pressure check with ~15 psi of air. Use a spray bottle with soapy water to find the leak.
Oil getting out IF you have a reservoir is one thing, and all you do is refill the reservoir. Water getting in the drive is completely different.
Philster
Ugh.
Got a reservoir.
The rest: Ugh.
