ShoalSurvivor
- Joined
- Aug 1, 2012
- 223
I just swapped my lower shifting cable, and changed the water pump while the lower unit was disassembled. I've performed this service multiple times and have been methodical and careful with assembly, using pins, and proper torque. I'm highly confident that everything was installed correctly. (including shift slide, water ring, gaskets...etc)
However, I forgot to drain the gear oil before servicing and made a huge mess inside the lower unit housing. I wiped everything up with dry towels, best I could, but there was certainly still film inside. I will NOT make that mistake again.
Today, I was warming her up in prep for an oil change. Startup was perfect, warmed up as usual, and water is flowing well from the outflows (using muffs). I have NOT shifted into gear or tested the shifting adjustments.
After a few minutes, I noticed that the outflow is not clear. it has a slight charcoal tint to it (mostly only visible as waves of water roll down the driveway). It also has a slight oil slick on top. I strongly suspend gear oil, but I don't know if its just cleaning out the housing, or if I biffed the service. I had topped off the remote gear oil tank, filled the outdrive to the top portal, and expected some additional fluid would be needed... but the remote is still at the full line.
I'd like to proceed with the oil change, because I already took it out of the garage to start up, and it's warm.. I think that's unrelated to my outflow problem, and I can just proceed and knock that out.
QUESTIONS:
1) any reason not to proceed with oil change, since its warmed up? (because I should NOT run the engine until the outflow is resolved?)
2) When would I expect the gear oil to fill into the lower unit from the remote fill tank? only after the lower unit is put into drive?
3) The plastic/rubber dam inside the lower unit is old (er). I doesn't look worse over last 6 years, but is old. Could that have failed?
4) If I soiled the inside of the housing in the void around the water pump housing, would that residue get burned off though exhaust heat?
5) Is this an obvious sign of the water tube not in place?
6) if I'm not in gear, and there is no other signs of a leak, is it ok to run for a while (how long?) to see if it gets "cleaned out"?
Thanks!!
Michael
original engine SN: L332123 replaced with: 2004 Mercruiser 4.3L 225hp 4bbl Quicksilver repower SN: 90004747 (#807736R11 / 03252004)
Alpha 1 Gen II - Transom: 0L517680 Drive: 0L192679 1.62 R (1.81R scratched on top) original drive may have been SN: L40356
QUESTIONS:
Thanks!!
Michael
