Gear oil leak from stern drive
Niebell13
Hey guys,
New to this boating lifestyle and have some questions. I bought a 1992 Bayliner Classic 1950 that was sitting for about 4 years. I got the engine up and running and have had it in the water a few times but I’ve noticed I’m leaking gear oil from the stern drive in my driveway. It appears to be coming from a small vent hole on the front side of the drive in front of the water intake but I don’t know why. I’ve changed the gear oil with new thinking it was just old but it’s still happening. Any ideas on what I can try or look for? Any help would be greatly appreciated. Thank you!!
Trying to attach pictures but they’re not working.
Scott06
Hey guys,
pictures are not working on this site at moment.
likely the seal under the water pump or shift shaft seal. take drive off drain oil and pressure test the drive use soapy water on seals to diagnose.
nola mike
Also I'm assuming a Merc alpha 1 Gen 1 until you tell us different
Scott06
92 would probably be a gen 2 , cut over year was 91 When merc started making them.
had a 1991 sea ray that had by serial number one of the last gen one drives made, serial was just below the cutoff …unless a builder had a bunch laying around
nola mike
You assume what you want I'll assume what I want! It's a Bayliner!
Niebell13
So it has a SEI116 installed on it, which from what I can find that’s an alpha one gen 2? Not sure how much that changes the likely hood of it being a seal in the lower unit.
Scott06
Yeah that is a gen 2 replacement drive
They have a 3 year no fault warranty that might still be in effect
Not all gen 2 drives have a lube bottle but I don’t think 1.75 qts fits on drive alone so look in engine compartment for a lube bottle
