JJsays77
- Joined
- Sep 21, 2011
- 59
Using a 1975 50 hp Johnson Seahorse. My gear oil has been leaking a bit. I first noticed it on the water when we were drifting. Then when I test it and run it for a while with the muffs it will leak a little bit. I've taken out a few times and just drained the oil just to see. There seemed to be a lot in there still but half of what is coming out is milky. As I understand it is because water is somehow getting mixed in with the gear oil. Is this a problem I should take care of asap and fairly easy to fix? What could be the problem? Or would it be easier for me to just change the oil every few trips? Is changing the oil every few trips a reasonable option?
