gear oil leak
cparker072
i have a gear oil leak behing the prop will the be fixed if i put a new prop seal on it or does the whole lower unit ned to be resealed
Daviet
Re: gear oil leak
You did not tell us what motor you have but if you are sure it is gear oil you can replace just the prop shaft seal(s).
Daviet
Re: gear oil leak
You have 2 seals, back to back, in the bearing housing. I think you will have to pull the bearing housing to change the seals, make sure to replace the sealing o-rings also.
cparker072
Re: gear oil leak
so this isnt a quick easy job of just taking the prop off and throwing a seal on
Daviet
Re: gear oil leak
I don't think so, do you have a manual on your engine? It would give you step by step instructions to replace the seals.
I am not able to get to a manual at this time, but I am sure an expert will come along and confirm the process.
Knightgang
Re: gear oil leak
You really need to get a manual. Even of you do not do the work yourself, at least you can understand what a Marine Tech tells you about your motor issues and you will be able to tell if he is blowing smoke or not...
In this case, not as easy as just pulling prop and changing seals. The outer end of the shaft housing (bearing assmbly) has ot come out... Not difficult to do if you have a manual and an exploded parts view diagram...
cparker072
Re: gear oil leak
the thing with it is it doesnt leak when its just sitting it leaks after i run for a while when i put it back on the trailer its like a milky sludge would that be gear oil or unburned oil
Knightgang
Re: gear oil leak
If it is milky then it has gotten some water in it and needs to be changed anyway..
cparker072
Re: gear oil leak
do you know if west marine sells the seal for the drain plugs cause there isnt a evinrude dealer close to me
Daviet
Re: gear oil leak
Have you pulled the drain screw and checked the gear oil? If the oil is not milkey and is full, I would think what you are seeing is unburnt gas/oil mixture which is not uncommon on a 2 cycle outboard.
Always best to check the easy things first.
cparker072
Re: gear oil leak
not yet im just going to change the gearoil tomorrow anyways so i knew what im up against just need to know if westmarine sell the washers for the drainplugs
crxess
Re: gear oil leak
A trick I learned that usually works to make the work short.
Remove prop
Drill small hole in seal flange. Caution stay away from aluminum casing.
Use screw in slide hammer to POP the seal out. Drill the second and do the same.
Use a piece of pipe of proper diameter to tap new seals in place.
I have sucessfully resealed several lower units/outdrives without pulling the assembly.
Daviet
Re: gear oil leak
If you have a NAPA store close they will be able to get them for you.
