How often we need to change the Gear Oil - is it yearly or never (just adding on it)? This is for my 85HP Force Outboard 1989 Model.
If I need to change/add the gear oil, do I have to use the recommended EP90 outboard gear oil from the instruction manual or SAE80W-90 will do? The Marina also suggested to use the mercury and I am not sure if this is acceptable? Thanks again for your help.
