My 205 V6,-86/87 No. 0A651138 does not have a shift interrupt switch installed. Do all the Alpha one outdrives have this installed? The engine runs on low idle, så the shifting have been no big problem. <br /><br />Another problem. I just got the boat, and after some slow and mid-fast testing I tried the max speed/rpm. On it's way up, it suddenly went out of gear. After this the shifting became hard. After disengaging the cables on the bracket and 'working' those a bit, they suddenly became quite smooth again. Do I only have an adjusting problem, or is there something wrong in the outdrive? Have not checked the adjusting described in this forum yet.
