Gear Ratio my boat
Jamz3333
I have a 1991 16' conquest with a 3.0. It has a Alpha one Gen II outdrive, the lower unit froze and busted and I need to know what the gear ratio is so I can get the same outdrive?
Thanks
emilsr
Re: Gear Ratio my boat
It'll be stamped on the starboard side of the upper unit of the drive, just above where the lower bolts on.
Jamz3333
could i put a alpha one gen II lower unit on my upper drive thats a different gear ratio? what would it do?
proshadetree
Yes you can change ratios but go to far and you will not be able to prop your boat back to normal rpm. What ratio do you have? Is this the same boat that leaks?
Don S
EDIT: REMOVED BACKWARDS INFO.
You need an upper with a 1.98 Gear ratio, other ratios are for bigger engines and will not work very well, even if you change props. That is why there are so many different gear ratios.
All you need is the lower unit, the gear ratio changes in the lower, not the upper.
Ayuh,... Must be beddy-bye time, eh Don,...
That's exactly Backwards...:D ;)
Gear ratio changes take place in the Upper unit....
The Lower units are all the Same ratio,...
Don S
:facepalm: Yeah, I kind of blew that didn't I :redface: :redface:
Repeat after me:
DO NOT watch TV and answer questions at the same time.
DO NOT watch TV and ................................................
proshadetree
Heck Don I thought he said the whole out drive. I will not do algebra and type on I boats again. Promise
Jamz3333
yes this is the same boat that is leaking ( i guess when it rains it poors...lol ) i didnt know if the gear ratio was decided in the upper or lower drive.
ok so any alpha one gen II lower unit will work on my upper drive?
oops!
lol....i have been on this forum 3 years.....i have read don;s posts and learned a ton......that is the first time i have seen him get dyslexic......lol....don ...im not gonna let you off the hook for a long time on this one...lol
bill.......thanks for backing us all up here....lol
Jamz3333
Ok cool, it gets so confusing when it comes to gear ratio thats I wasn't sure about upper and lower units. Anyways thanks for everyones input!
