Re: gear select switch in 72 johnson controls
Rigging any type switch would work as long as the voltage being applied is as follows:<br /><br />Neutral = 12v to green wire only.<br />Reverse = 12v to both Green & Blue wire.<br />Forward = No voltage applied.<br /><br />The drawback would be that it would be possible to shift from forward to reverse at full throttle, which in my opinion is going to cause quite a lot of damage.
