Deepblue22
- Joined
- Mar 31, 2007
- 51
Having problems with the gear shifting. This is a Volvo 5.0 GxiB(F)-Sx on a 2002 Seaswirl Striper.
Sometimes the shift lever will bind and not go forward. If I push the little button at the base to bypass the gearshift, then it will go forward and I can increase / decrease the throttle with no problem. Sometimes, when it is in forward, I pull back into neutral position, but the gears are still turning and it is still powering forward. Once, I shifted into reverse to back out of the dock, and instead of going backward, the boat went forward ! Sometimes, it works fine, as designed. In all instances the throttle advances fine so the problem lies with the gear shifter. It is definately unpredictable, and unsafe.
I took it to the dealer who did some kind of adjustment but that did not solve the problem and it re-occurred on my first trip to the ocean.
Anyone with thoughts on the cause or solution:
1. is this problem in the gear shift lever or where it attaches to the drive
2. should I try to repair this or just buy a whole new gear/throttle lever ?
3. recommended repair procedure
Thanks !
Thanks !
