gear shim code location
Matthew A.
I, for the life of me cannot find the shim code number or letter anywhere on the forward gear. Can anyone please clue me in as to the size and location I might such information. Also, would such information be stamped, lasered, etched, printed or ? on the gear. I might have located what might appear to be the numerial 20 lasered "very small and via very small dots" on the side of the gear. However, I might be biased to believe I am seeing the number "20" due to my uncertainty of the various readings I get when "mic"ing the shims. [shims sustained considerable damage when seperating the bearings inner race from the gear] The readings I am able to average out are .009" for the one steel shim and .007" for the two brass shims. HSG code on housing is "3". Codes 20 and 3 codes equal .023" for shim thickness [According to Seloc]
