Spinnaker
- Joined
- Jul 5, 2009
- 210
I am reassembling a Merc Alpha upper unit and have come across an issue with what I am reading in the manual. The manual states to tighten the nut on the gear yoke until you start to feel the drag on the bearing. Then turn the nut 2 x 360 then 1/3 turn. At this point set the preload with a torque wrench to spec. Depending on new or the original bearings and shims. "SELOC Manual page 10-30 to 10-31. Steps 25 and 26.
My problem is that when I turn the nut down til I feel drag on the bearing I can only turn the nut not even half turn.
Why is this ? Your help is very appreciated.
