Steven Bates
- Joined
- Oct 12, 2012
- 33
Hi guys, recently fitted the ol 125 to our boat, and howl!!! It was going beautifully- motor still is
very pleased. Was engaging the gear at low revs very smoothly. Now no. Motor just revs and box makes a sound like teeth chattering? Now it just won't go into gear... Shift rod bouncing around and won't engage properly~ will lock into gear when in shed and turned off, but on water and motor running just chatters... I took the forward controls off, disconnected the throttle and tried to just engage gears- no good! Is this a adjustment issue or maybe something internal in box? I changed box oil, seemed to be no metal in old oil... Was a bit discoloured... I also tried to adjust rod length using nuts on top. I Am out of ideas~ surely there's a fix or do you think box must come apart? (boat was towed over some ridiculous corrugated roads last trip...). Any thoughts appreciated... And may help me stay sane
cheers guys~ Aussie Steve
