I have a 1985 200hp OMC sea drive. I am in the process of tearing my gearcase down after I pulled the drive shaft out of it, due to a crankshaft/driveshaft marriage. I am trying to replace the driveshaft retainer and any other parts that may have been damaged during my removal process as well as looking for any pieces that may have broke loose. <br />Currently, the upper drive shaft is out, the reverse gear is out, the pinion locknut is off and the prop shaft is still in. The manual tells me to remove the pinion gear, but the gear does not want to come loose. Is it suppose to just slide off the lower drive shaft (two piece driveshaft)? I'm affraid to stick anything inside the gearcase to pry with for fear of damaging the side walls. Is there an easy way to get the gear out or am I in for a battle? Or am I just overlooking something, hopefully! <br />Thanks in advance for your assistance. <br />Steve
