gearcase oil black and smells burned
polk county
The oil in the lower unit of my 25hp 2003 has a black color and smells burned.
The gearcase oil hasnt been change in 5 years.
What should I do?
Thanks
JustJason
Re: gearcase oil black and smells burned
you should change it.
polk county
Good advice. I thought the lower unit might be overheating.
Thanks
Evinrude Boater
Gear oil is usually amber or milky if water has leaked into the gear case. I would want to determine what has discoloured the oil. In a 4-stroke engine the oil darkens with the products of combustion but in a gear case there's just gears. Does this occur in new motors as the gear case wears in?
wbeaton
That's the colour of spent gear oil. Its also why you should change the oil every year.
ezeke
Right, any oil in use wears out over time, turns black and stinks.
HighTrim
....and dont forget to change both the vent and drain screw gaskets along with the oil. You dont want water intrusion into that new lu. If you dont have one, these oil pumps work well, better than the tubes I find.
Silvertip
Gear oil has a very distinct odor when new so don't let that be a deciding factor as to whether or not you have a problem.
Cricket Too
My gear oil comes out like that almost every time I change it, which is once a year in the fall. That's what happens to it over time, and use.
I usually put about 100hrs on my engines per season and a lot of that is long, hours long runs out off shore. LU oil takes a lot abuse, heat changes it's color and smell.
I can't imagine why it hasn't been changed in 5 years, since it takes about 20 minutes to do, but I wouldn't try that again unless you like to buy new lower units.
5 years of abuse on the same oil is a lot for it. I'm surprised you don't have any water in it.
Change it, run it and then check it in 10 hours and see what it looks like.
As was mentioned go buy the fill and drain gaskets, and don't try to re-use them, thinking they are probably still good since they were just changed last year. They are one-time use ONLY, they are crush washers, when you tighten them they crush and they only crush once. So replace them everytime, might as well buy a bag of them, they are cheap.
Change it every Fall from now on if you want to keep it.
