1985 Mercruiser 260...
I just recently replaced all of the seals, water pump, etc... in my outdrive. all of the gears and bearings looked great. Got everything cleaned up and re-assembled per the factory manual and it was all working good.... Until this Saturday.
I had spent most of the morning pulling people on the wakeboard so it was a lot of stop and go. Later in the afternoon we took a cruise down the lake (probably about 1.5 hours cruising around 3000 rpm's) and I heard a couple "pops" and the boat quit moving. Today I finally took the drive apart and found the gears in the upper unit completely destroyed, and it also ate up the inside of the gear housing pretty good in a couple spots. I attached a couple pictures for reference.
What do you all think? Can I replace the gears/bearings/races and be OK or should I get a whole new upper unit? What might have caused this, maybe broke a tooth on a gear then it destroyed the rest? I just want to make sure something else in the driveline didn't cause this so I don't destroy the new ones.
