Just replaced prop shaft, driveshaft, water pump and shift cover seals on lower unit. Pressure test passed so filled with oil then tested shifting manually by pushing and pulling shift rod to engage forward and reverse gears. About 1 every 3 times I engage either forward of reverse and turn the driveshaft manually, the prop shaft doesn't turn. If I then put a little more pressure and hold the shift rod, it was engage and the prop shaft will turn, even though it doesn't seem like the shift rod moves any further up or down. Is this normal while removed from the engine and engaging manually?
Here's a list of what I removed and cleaned while opened up to replace the seals.
Propshaft Seals: Pulled bearing carrier, replaced outer needle bearing and shaft seals, pulled out thrust washer, thrust bearing, reverse gear, and mini thrust washer.
Driveshaft Seals: Pulled bearing housing, replaced shaft seals, removed/cleaned/reinstalled 2 shims, thrust washer, thrust bearing
