I have some rotten wood on my 84 sportcraft and am planning on replacing it with plywood. The areas that are rotten are mostly cosmetic (side panels of cockpit, panel covering bilge/transom area). The original wood is some sort of laminated plywood but is in bad shape. I would like to repalce it with something more weather proof. Would it be best/easiest to coat it with epoxy resin and then paint or gel coat it. It's just a fishing boat so nothing fancy is necessary, just looking for a easy/cheap but effective answer. Thanks for any suggestions.
