Re: Gel coat or paint
With either one you will need to clean it up and do some sanding, the prep is about the same. Gel coat will hide more of the surface texture because it goes on thicker, paint will have more gloss. A stiff wire brush will roughen the low areas in the glass pattern so you won't need to sand it down completely.
