Gel repair on 1987 Four Winns Candia
johnmogs
1987 Four Winns Candia 200,
Hi, First time post for me, but have learned a lot on the engine side, I have no experience with fiberglass so I'm hopeful this is not that hard of a project.
Previous owner's dock had damaged front exterior of boat, he primed it white, unfortunately not prepped very well, so I'm not sure exactly how deep the damage is/was but it looks like the dock took out some 1/4 to 1/2 inch(both deep and roundish) chunks. I'd like to get it looking a bit more original to match the boat, and I think I need to prep and apply gel coat, but wanted to ask the experts here first. No leaks as this is above water line. I have no experience with fiberglass repair. Also curious what a pro would charge for this type of repair and if anyone in the Detroit area could recommend a guy.
I'm in Michigan, freshwater lake if that helps.
Thank you in advance!
Yacht Dr.
Re: Gel repair on 1987 Four Winns Candia
Hello John and welcome to Iboats :) .
Welp..if you want Gelcoat back on there your going to have to sand all of that primer off ( unless its duratec ). But you probably dont know what primer is on there :( .
After you sand the primer off ( with 120 grit ) you then can see how and what he repaired it with. If its Bondo then I suggest you redo it.
Give some more info and pics after you explore your repair.
For a pro to do this .. Im thinking about ( assuming the repair is sound and fair ) 1hr to prep,1hr to spray 2 colors,1hr to sand and buff + materials. This is Me doing this with my tools.
But Im sure your local pro shop will charge ya 8 hrs+mat ( 1000 bucks ).
If you want I can get you the color names ( white is going to be "aztec surf white" if Im not mistaken ).
YD.
johnmogs
Thank you Yacht Dr.
Before I start, the boat's gelcoat has a lot of oxyidized, should this be buffed before or after I do this repair?
Thank you
Yacht Dr.
Thank you Yacht Dr.
Thank you
Wow..no comments from others..hmm..
Yes I would buff out before the repairs are done. Just in case you start burning through the gel ( Dont do this oversanding and/or over buffing to make it look like a mirror around your repairs leave it for the prep and final blend buffing ). Leave about 1' around your repair before you buff those spots out.
YD.
Buff Wheeler
Banned
Check out NAUTICARE. They do exceptional work and have sensible prices.
