Re: GELCOAT OXODIZED
I used the heavy cut compound, the stuff that will level orange peeled paint, yes the gelcoat was clean before I applied carnauba wax.<br /><br />Says in instructions to use their boatwash...do you have to? Is is "required" or just trying to get more sales.<br /><br />It's included with the package.<br /><br />Says apply 2 coats per year and that you need their product to remove it if you accidently cover dirt etc. Should you strip it before applying the 2 coats or are you going to get a build up?<br /><br />This is to renew the shine, just wash the hull, let it dry, apply. The remover is included.<br /><br />Any yellowing/cloudiness after say..5 years at 2 coats per....?<br /><br />First year I've used this product, if there is, I'll use the remover and reapply.<br /><br />Did you use there oxidation remover also?<br /><br />Yes, instructions stated, "Use a small amount" I did, used too much elbow grease instead of the oxidation remover, had half a bottle left, pad was worn down to the handle. <br /><br />Two friends of mine that also own boats took one look at mine and did their boats.
