Since I've never done enough gelcoat repairs to be able to answer my own questions. I'd appreciate anyone knowledgeable to chime in.
I was shooting unwaxed gelcoat (fire engine red pigment) with 5% styrene over existing theme white/burgundy 19 footer.
After using 1gal shooting two coats I've realized my catalyst ratio was way off. As calculated Ive mixed only .35% catalyst. Recommeded for that gel is .75-1.5%.
Weather was in 80s.
As soon As i found out catalyst was at low percentage i stopped.
That was last night.
Today,before i left to work i quickly peeked in to see the gel, touched it and left no fingerprint. Once i get back home ill do closer investigation.
Forecast for today is sunny in mid 80s. In tent that im spraying is probably 20degrees more easy.
Now.
Is there any hope for me to continue shooting remaining layers? How do i make sure gelcoat cured enough to lay extra coats on top? wipe it with acetone see if it comes off?
Weather was in 80s.
Now.
