Gen II gear oil
kpoly
I noticed some gear oil coming from the vent on my Merc Gen II Alpha One. I also noticed there is a reservoir in the boat next to the engine for gear oil. Is the Gen II outdrive a sealed unit or does it hook to a reservoir? Is it normal to have gear oil coming from the vent hole on the side of the outdrive? Thanks.
its connected to the reservoir
it is not normal to have gear oil coming from the vent
most likely you have a seal that has gone
kpoly
Is the seal generally in the upper or lower unit? How much work is involved?
no more work than replacing the impeller every 3 years
kpoly
What seals would generally be replaced and is the leak generally in the upper or lower half?
Bt Doctur
2 back to back seals for the driveshaft, 1 driveshaft seal under the water pump ,1 shft shaft seal for the shift rod.
CurrentObsession
Can someone provide a step by step guide to changing these seals? Perhaps a link to a certain section of a manual.
Ayuh,.... The factory manuals can be found by clickin' the link Don'S Adults Only Section, in my signature,....
