General Maintenance
EJ3
I did a search on the topic but wasn't able to find what I am looking for. If there is a topic already started please point me in the right direction!
General outboard Maintenance...
I pretty much spend my time on the water in saltwater. After every outing I flush the engine with fresh water. Every couple of outings I look at the lower unit oil, spark plugs, compression, battery and generally look over everything to see if there is anything I should take a deeper look into.
Is there a "checklist" of things that are a good idea for general upkeep?
tashasdaddy
Re: General Maintenance
sounds like you are doing pretty good. much more than most. but it will pay off in the long run. only addition i would add is to grease the fittings. there is one hidden, you have to tilt the motor up to find it.
EJ3
Are the fittings you speak of the ones with the little grease nipples? Or are there more to keep an eye on?
Thanks!
