vroom ZOOM
- Joined
- Aug 15, 2017
- 462
Hello, I have a fairly general map sensor question. The engine is a 2008 DF200, but that is not really relevant. My map sensor was showing 117 kpa pressure when I removed it in my hand. I tried blowing or sucking on it but that does not change the reading. After tapping it against the intake manifold it changes the reading with pressure. Approximately what readings should it be showing with the engine running or stopped? Also, would the 117kpa pressure reading while idling cause the engine to run bad and over fuel? Thanks
