I have a Kohler 4.0 generator that keeps shutting down when getting on or off plane. It will run all day no problem as long as the boat is level however once you get it at an angle it shuts down. On plane or off doesn't matter, the genset runs fine. Load or no load doesn't matter, just shuts off when you get on that angle.
I know about the oil shut off sensor. The oil level is spot on. I've also checked the coolant level and it is correct as well. Does anyone have any suggestions on how to solve this? I'm just guessing that the oil sensor is the issue. Is there anything to check or be done there since it runs fine at all other times?
Thanks,
Nate
Thanks,
Nate
