Generator wiring help
Pavetim
Have a 2000 sea ray amberjack 290 and i think it came with a westerbeke genny but i put in a cummins onan 6.5. Now it was prewired and the wires i see are 3 wires sort of like a home 3 wire electeical cable and there are postive and negative battery cabkes that dont reach the batteries. I can send pics if needed but need to know how to hook it up.
Pavetim
Here are 2 pics of wiring. I am assuming the 3 big wires goes to the control panel? Is that harness for anything? I couldnt get a pic but there is positive and negative battery cables which i assume to to the battery for staryer. I guess my main question os for the 2 pictires.
Agree model number would help
My guess, is the Black/White/Green is the 120V out
The plug is normally feeds into a remote start panel. If a remote panel isn't used it normall works fine without connection
Pavetim
Yes those 3 wires are for the output i know cause it has a plug end spliced in for a portable genny. But do those wires also go to the control panel or is that what the harness is for? I Need to know where to hook those 3 wires as service manual diagram is crap. I know where the battery cables go.
Normal installation of a Gen with shore power those wires feed to a shore power/Gen power breaker. This way you can have either shore or Gen powering the 120VAC outlets. If your boat does not use 120VAC shore power then the breaker is not needed, but should go to a main breaker which feeds all outlets/accessories
Pavetim
The panel has a switch for shore power and generator. Originally came with a westerbeke so will be harder to figure the wires out. Ill just get it hooked up for now amd start it up in the engine bay until i can figure out the control panel
Pavetim
Still trying to figure this out. Got power to generator from the battery got all my water lines done just need to fogure out the control panel 3 wires. Also of i dont hook up the control panel for now what will actuate the solenoid before the filter?
need to figure out the control panel 3 wires
Which 3 wires?
Unsure, but most Gen's will run the same without the extension panel, they are just parallel input
GA_Boater
You could wire 12 DC volts or 110 AC as appropriate to the solenoid. Genny starts and the voltage from the generator energizes the solenoid. Shut the generator off and the solenoid de-energizes to close the valve.
Grub54891
Do us all a favor and get rid if the extension cord wire. The orange one. Replace it with marine grade romex.
