Rick Stephens
- Joined
- Aug 13, 2013
- 6,118
All ya'all ever see a water leak out around the upper gear case top cover - on muffs, on an Alpha1 GenII?
I know there are cooling passages around the upper gear case, but they shouldn't be able to leak out around the top cap. Should they? No water getting in the gear oil at all. Just dribbling out all around the cap. I pulled the leg tonight and everything is dry in the bellows and shifter slot.
I just completed a complete power package swap in my boat and was running the motor first time in the boat today on muffs. I swapped EVERYTHING, from transom, outdrive to the complete motor, going from a 3.0L to a 4.3L. This is my first time working on a GenII. And I went through pretty much every bit of maintenance on it possible without pulling gear sets. I saw nothing didn't look like new in the top when I pulled the cap to inspect input bearing.
Thanks for any thoughts. I'll pop the leg back on and run it tomorrow and gets pics of the leak if it seems out of normal.
Rick
Rick
