JustJason
- Joined
- Aug 27, 2007
- 5,321
Ohhh the weather outside is frightfull.....
And in new england...... nothing works well.....
Okay folks... We had a major ice storm in all of NE with some pretty serious damage. I've had no power since thursday.... and probably won't get it back untill this thursday at the earliest.
My GF's (girlfriend) BIL has a Honda Gen.... but die's out at WOT. With or without a load. Engine overrevs and the govenor surges and chokes out the motor. It's 4 years old and never gets run. I take the carb off. No visible varnish or junk. I hose the thing with carb cleaner and compressed air.... just like any outboard carb I clean... Put it all together, set idle mixture, fire it up then load the genset up and check the GOV..... all is well according to the specs on the sticker.... And it now runs fantastic...... It's within 100RPM of it's max rated and has been going 7+ hours straight without a hiccup. Something will kick on... gen loads up... engine bogs for a second or 2 then the GOV does it job and no problems at all.
So then my GF's parents let me borrow a genset from her foreverly deceased grandfather..... a coleman powermate with a tecumseh engine..... supposedly 4000 Watts. It has to be 25+ yearls old.
Hasn't been run in at least 10 years. I can't find any id's on the motor other than tecumseh stickers all over it...... I'll look again tomorrow when it's light out but so far I can't find a model or serial..... let alone spec's for the thing.... so i'm doing this all by ear.
GF's father knows i'm coming to look at it and decides to throw some gas in it before I get there. And..... he throw's (of course) pre-mix in it (it's a 4 stroke motor) and he puts gas for the chainsaw gas can in it.
I mess with it for a bit. And get it to run okay. I think its probably a 8 to 12 horse engine based off of the size of the block... eyeballing it..... but of course i could be wrong..... with no ###'s or specs to look at. (best WAG)
Even after my best engine doesn't run for anything.
Spark is hot and fairly blue on the Steven's spark board at 1/2 inch.
Fixed timing engine.
Compression 110psi.
Not positive if it has the correct plug in it.... i just cleaned and regapped the plug that was in it to .30
After all that.... i pulled the carb and it was a mess..... So I cleaned it. Dumpd the fuel tank... put fresh 87 in it and it was a million times beter. Start it and run it.... plug in some stuff and put a load on it... and then set the adjustable high speed jet by ear. (there is no low speed..... only a mixture screw) In fact this has not low speed at all.... it starts then rev's up to WOT...then the GOV takes over.
Problem i'm having is this..... Engine runs fine for 45 minutes under a medium load (if I did my watt's law correctly... and i think I did). Runs everything OK... then just dies.
If I unplug everthing..... and screw with the mixture scres it runs grreat againl... for another 30 min's or so...... then dies.
Every time it dies it takes 10+ minuted of messing with the highspeed screw to get it to to run at all...... then a litttle fine tweakin when it's loaded. The time frame varies........ sometimes its 10 minutes withoug a hiccup..... other times' it's 45.... I can't find a pattern to it yet.
My best guess is..... is the engine is underpowered to start with. and loading it doesn't help. It will work for 46 minutes withought a hiccup.... then it just dies.
I'm obviously skiipping out on either fuel spark or air.... but I can't get this one yet.
So my question is...... have any of you guys had a hard time with old motors that were originally designed to work off of a different forumula of gas. ethanal doesn't have the BTU's of normal gas does.
I have no idea why this thing can run for 45 minutes fine then crap out all off a sudden.... with no apparent change in engine loat.
Anybody have any ideas???/
Thanks
J
Compression 110psi.
Thanks
J
