Re: GEONAV 6plus NOT finding Satellites ???
From your manaul:
Since the GPS receiver is initialized in Italy, the time to get the first
fix will depend on the areas you want to navigate in; within the
Mediterranean Sea the GEONAV should get the first fix in less
than 12 minutes, whereas in other parts of the world it can take
up to 30 minutes. Once the unit gets the first fix, the time for the following fixes is a few minutes.
If the boat is in an area covered by a differential station, when the
built-in antenna is used together with a DGPS, the top of the screen
will display the ?FIX 3D-DIFF? or ?FIX 2D-DIFF? message.
