Re: Get boat off trailer
Unless the boat is at a height of approximately 1/2 the height of the trailer or more, attempting to pull the boat back onto the trailer results in a very steep keel angle. Ive see keels broken attempting this. I've also seen aluminum boats bent doing this. Your boat is not very big, nor is it terribly heavy. Lower the tongue as low as it will go. Block the back of the boat (tires, barrels, blocks of wood, whatever you can round up. Support it at the transom. Raise the tongue which lowers the back of the boat and essentially causes the boat to lift off the trailer. Place a steel bar through the bow eye and with a few buddies to do the lifting, remove enough pressure on the bow to slide the trailer out. As the bow clears the keel roller, gently low the bow onto a tire or two. If you have a garage with a sturdy header over the door, post back for another technique.
