SunTrackerPB21
- Joined
- Aug 15, 2008
- 41
I'm going to build a 8'W X 16'' long 'dolly' so that I can put my SunTracker 21' away in the garage for the Winter. The boat alone (~6ft high) will fit inside but it won't go in on the trailer (8'4" high) and the trailer is too long (26') to get the door shut so my question is: any ideas on how to jack up the boat in my driveway to get the trailer out from underneath, so I can then roll in the dolly and set the boat back down onto it.
I've bought 6 - 4" casters (660 lb capacity) 3 on each side of the dolly, to support the boat @ about 1600 lbs.
I've considered passing a couple of 2X6's (maybe doubled up) from side to side, UNDER the deck and ABOVE the logs so I have 4 "ends" sticking out, one on each corner more or less, then jacking these (~400 lb) "corners" up (with blocking-so I dont have to jack UP too far) with my garage jack til I get enough height to clear the trailer...only have to lift it maybe 4", then out with the trailer & I'll roll the dolly in underneath.
It rolls easily on the trailer on my level gravel RV parking area so should be no problem rolling it into the garage on the concrete driveway/garage floor.
Has anyone tried anything like this ?
