I want to drain the gas out of the carb for winter storage. There is a round yellow/white plastic drain plug at the bottom front of the carb which I can get to if I remove the lower cowl. But that is a royal pain to do (trying to get the nut/bolt off on the front portion of the cowl) - so I wondered if there is a trick to getting at that drain plug without having to pull the cowl. It looks like I might be able to push the rubber grommet on the enrichment dial side of the front over to one side then get a screwdriver in there - but thought I would ask first.
